Solving First Degree Equations with Two Unknowns
First degree equations with two unknowns can be expressed as
a1 x + b1 y = c1 (1)
a2x + b2y = c2(2)
Example - Two Equations with Two Unknowns
The two equations
3 x + 5 y = 7
4 x - 3 y = 19 <
with the two unknown x and y can be solved by rearranging (1) to
y = (7 - 3 x) / 5
and substituting this expression for y in (2)
4 x - 3 ((7 - 3 x) / 5 ) = 19
- the value for x can then be calculated to
x = 4
By substituting this value for x in expression 1
3 4 + 5 y = 7
- the value for y can be calculated to
y = -1
Online Calculator for Two Equations with Two Unknowns
The calculator below can be used to estimate x and y values for two equations with two unknowns.
Mathematics
Algebraic Expressions
Principal algebraic expressions formulas.
Circles within a Rectangle - Calculator
Calculate the maximum number of circles within a rectangle - can be used to calculate the numbers of pipes or wires in a conduit or similar.
Discrete Data Sets and their Mean, Median and Mode Values
Calculate the arithmetic mean, median and modal values from discrete data sets.
Numbers - Square, Cube, Square Root and Cubic Root Calculator
Calculate square, cube, square root and cubic root. Values tabulated for numbers ranging 1 to 100.
Numbers - Standard Form, Scientific and Engineering Notation
The difference between standard, scientific and engineering number notation.
Prime Numbers
Prime numbers up to 1000.
Solving Equations of the First Degree with One Unknown
Equations with one unknown.
Solving Quadratic Equation with One Unknown
How to solve a quadratic equation.
