Refrigerants - Environmental Properties
Common refrigerants and their Ozone Depletion Potential (ODP) and Global Warming Potential (GWP) are indicated below.
  • Ozone Depletion Potential (ODP) of a chemical compound is the relative amount of degradation  it can cause to the ozone layer
  • Global Warming Potential (GWP) is a measure of how much a given mass of a gas contributes to global warming. GWP is a relative scale which compares the amount of heat trapped by greenhouse gas to the amount of heat trapped in the same mass of Carbon Dioxide. The GWP of Carbon Dioxide is by definition 1. Be aware that GWPs are highly controversial.
RefrigerantOzone Depletion Potential
(ODP)
(GWP)
R-11 Trichlorofluoromethane 1.0 4750
R-12 Dichlorodifluoromethane 1.0 10900
R-13 B1 Bromotrifluoromethane 10
R-22 Chlorodifluoromethane 0.05 1810
R-32 Difluoromethane 0 675
R-113 Trichlorotrifluoroethane 0.8 6130
R-114 Dichlorotetrafluoroethane 1.0 9800
R-123 Dichlorotrifluoroethane 0.02 77
R-124 Chlorotetrafluoroethane 0.02 620
R-125 Pentafluoroethane 0 3500
R-134a Tetrafluoroethane 0 1430
R-143a Trifluoroethane 0 4300
R-152a Difluoroethane 0 120
R-245a Pentafluoropropane 0
R-401A (53% R-22, 34% R-124, 13% R-152a) 0.037 1100
R-401B (61% R-22, 28% R-124, 11% R-152a) 0.04 1200
R-402A (38% R-22, 60% R-125, 2% R-290) 0.02 2600
R-404A (44% R-125, 52% R-143a,  R-134a) 0 3922
R-407A (20% R-32, 40% R-125, 40% R-134a) 0 2110
R-407C (23% R-32, 25% R-125, 52% R-134a) 0 1774
R-502 (48.8% R-22, 51.2% R-115) 0.283 4657
R-507A (45% R-125, 55% R-143) 0 3985
R-717 Ammonia - NH3 0 0
R-718 Water - H20 0 0
R-729 Air 0 0
R-744 Carbon Dioxide - CO2   1*
*  CO2 is the GWP reference
Air Conditioning Systems
Environment
Concentration of Carbon Dioxide in the Atmosphere
The atmospheric Carbon Dioxide concentration year 1959 - 2015.
Dichlorodifluoromethane - Properties
Properties of saturated liquid Dichlorodifluoromethane R-12 - CCl2F2 - density, specific heat capacity, kinematic viscosity, thermal conductivity and Prandtl number.
Global Temperature Trend
Global temperature trend year 1880 - 2015.
R-12 Dichlorodifluoromethane - Properties
Thermodynamic properties of saturated and superheated Dichlorodifluoromethane (CF2Cl2), like specific volume, enthalpy and entropy.
R22 Refrigerant - Properties
Properties of Refrigerant R22 Dichlorodifluoromethane - saturated liquid and saturated vapor - imperial and metric units.
Refrigerant Compressors - Evaporation Temperature, Condensating Temperature and Capacity
Evaporation temperature, condensing temperature and refrigerant compressor capacity.
Refrigerant R134a - Properties
Thermodynamic properties of refrigerant R-134a.
Refrigerants
Commonly used refrigerants - the methane series, ethane series, propane series, cyclic organic compounds, zeotropic blends, azeotropic blends and organic compounds.
Refrigerants - Color Codes
Common refrigerants and their color codes.
Physical and environmental properties of some common refrigerants.
Refrigerants - Physical Properties
Physical properties of refrigerants - molecular weight, boiling, freezing and critical points.
Refrigerants - Pressure vs. Temperature Charts
Temperature and pressure chart for refrigerants R22, R410A, R12, R134A, R401A, R409A, R502, R404A, R507A, R408A and R402A.
Refrigerants - Saturation Pressures vs. Temperatures
Temperature and pressure diagram for constant boiling refrigerants - imperial and SI units.
