Dry Air - Thermodynamic and Physical Properties
Properties like
- specific heat
- ratio of specific heats
- dynamic viscosity
- thermal conductivity - a measure of how quickly a material can absorb heat from its surroundings.
- Prandtl number
- density
- kinematic viscosity
- thermal diffusivity
of dry air at temperatures at one atmosphere from 175 K to 1900 K .
For full table with Ratio of Specific Heats, Thermal Conductivity, Prandtl Number, Kinematic Viscosity, Density and Diffusivity - rotate the screen!
Temperature ( K ) | Specific Heat | Ratio of Specific Heats - k - ( cp /cv ) | Dynamic Viscosity - μ - (10 -5 kg/m s) | Thermal Conductivity (10 -5 kW/m K) | Prandtl Number | Kinematic Viscosity 1) - ν - ( 10 -5 m2/s) | Density 1) - ρ - (kg/m3 ) | Thermal Diffusivity - α - (10-6 m2/s) | |
- cp - (kJ/kgK) | - cv - (kJ/kgK) | ||||||||
175 | 1.0023 | 0.7152 | 1.401 | 1.182 | 1.593 | 0.744 | 0.586 | 2.017 | |
200 | 1.0025 | 0.7154 | 1.401 | 1.329 | 1.809 | 0.736 | 0.753 | 1.765 | 10.23 |
225 | 1.0027 | 0.7156 | 1.401 | 1.467 | 2.020 | 0.728 | 0.935 | 1.569 | |
250 | 1.0031 | 0.7160 | 1.401 | 1.599 | 2.227 | 0.720 | 1.132 | 1.412 | 15.72 |
275 | 1.0038 | 0.7167 | 1.401 | 1.725 | 2.428 | 0.713 | 1.343 | 1.284 | |
300 | 1.0049 | 0.7178 | 1.400 | 1.846 | 2.624 | 0.707 | 1.568 | 1.177 | 22.18 |
325 | 1.0063 | 0.7192 | 1.400 | 1.962 | 2.816 | 0.701 | 1.807 | 1.086 | |
350 | 1.0082 | 0.7211 | 1.398 | 2.075 | 3.003 | 0.697 | 2.056 | 1.009 | 29.50 |
375 | 1.0106 | 0.7235 | 1.397 | 2.181 | 3.186 | 0.692 | 2.317 | 0.9413 | |
400 | 1.0135 | 0.7264 | 1.395 | 2.286 | 3.365 | 0.688 | 2.591 | 0.8824 | 37.66 |
450 | 1.0206 | 0.7335 | 1.391 | 2.485 | 3.710 | 0.684 | 3.168 | 0.7844 | |
500 | 1.0295 | 0.7424 | 1.387 | 2.670 | 4.041 | 0.680 | 3.782 | 0.7060 | |
550 | 1.0398 | 0.7527 | 1.381 | 2.849 | 4.357 | 0.680 | 4.439 | 0.6418 | |
600 | 1.0511 | 0.7640 | 1.376 | 3.017 | 4.661 | 0.680 | 5.128 | 0.5883 | |
650 | 1.0629 | 0.7758 | 1.370 | 3.178 | 4.954 | 0.682 | 5.853 | 0.5430 | |
700 | 1.0750 | 0.7879 | 1.364 | 3.332 | 5.236 | 0.684 | 6.607 | 0.5043 | |
750 | 1.0870 | 0.7999 | 1.359 | 3.482 | 5.509 | 0.687 | 7.399 | 0.4706 | |
800 | 1.0987 | 0.8116 | 1.354 | 3.624 | 5.774 | 0.690 | 8.214 | 0.4412 | |
850 | 1.1101 | 0.8230 | 1.349 | 3.763 | 6.030 | 0.693 | 9.061 | 0.4153 | |
900 | 1.1209 | 0.8338 | 1.344 | 3.897 | 6.276 | 0.696 | 9.936 | 0.3922 | |
950 | 1.1313 | 0.8442 | 1.340 | 4.026 | 6.520 | 0.699 | 10.83 | 0.3716 | |
1000 | 1.1411 | 0.8540 | 1.336 | 4.153 | 6.754 | 0.702 | 11.76 | 0.3530 | |
1050 | 1.1502 | 0.8631 | 1.333 | 4.276 | 6.985 | 0.704 | 12.72 | 0.3362 | |
1100 | 1.1589 | 0.8718 | 1.329 | 4.396 | 7.209 | 0.707 | 13.70 | 0.3209 | |
1150 | 1.1670 | 0.8799 | 1.326 | 4.511 | 7.427 | 0.709 | 14.70 | 0.3069 | |
1200 | 1.1746 | 0.8875 | 1.323 | 4.626 | 7.640 | 0.711 | 15.73 | 0.2941 | |
1250 | 1.1817 | 0.8946 | 1.321 | 4.736 | 7.849 | 0.713 | 16.77 | 0.2824 | |
1300 | 1.1884 | 0.9013 | 1.319 | 4.846 | 8.054 | 0.715 | 17.85 | 0.2715 | |
1350 | 1.1946 | 0.9075 | 1.316 | 4.952 | 8.253 | 0.717 | 18.94 | 0.2615 | |
1400 | 1.2005 | 0.9134 | 1.314 | 5.057 | 8.450 | 0.719 | 20.06 | 0.2521 | |
1500 | 1.2112 | 0.9241 | 1.311 | 5.264 | 8.831 | 0.722 | 22.36 | 0.2353 | |
1600 | 1.2207 | 0.9336 | 1.308 | 5.457 | 9.199 | 0.724 | 24.74 | 0.2206 | |
1700 | 1.2293 | 0.9422 | 1.305 | 5.646 | 9.554 | 0.726 | 27.20 | 0.2076 | |
1800 | 1.2370 | 0.9499 | 1.302 | 5.829 | 9.899 | 0.728 | 29.72 | 0.1961 | |
1900 | 1.2440 | 0.9569 | 1.300 | 6.008 | 10.233 | 0.730 | 32.34 | 0.1858 |
1) At pressure 1 atm
• Air Psychrometrics
• Densities
• Viscosities
Density and specific volume of air varies with elevation above sea level.
Air - Density vs. Pressure and Temperatures
Air - Dynamic and Kinematic Viscosity
Air - Humidity Ratio
Air - Specific Heat vs. Temperature at Constant Pressure
Online calculator with figures and tables showing specific heat (Cp and Cv) of dry air vs. temperature and pressure. SI and imperial units.
Air - Speed of Sound vs. Temperature
Speed of sound in air at standard atmospheric pressure with temperatures ranging -40 to 1000 °C (-40 to 1500 °F) - Imperial and SI Units.
Thermal properties of air at different temperatures - density, viscosity, critical temperature and pressure, triple point, enthalpi and entropi, thermal conductivity and diffusivity and more.
Humid Air - Heating
Humid Air vs. the Ideal Gas Law
Pressure, temperature and volume in a perfect ideal gas like moist air (air with water vapor).
Moist Air - Properties
Psychrometric table with humid air properties like saturation pressure, specific volume, enthalpy and entropy.
Moist Air - Water Vapor and Saturation Pressure
Saturation pressure of water vapor in moist air vs. temperature.
Moist Air - Weight of Water Vapor
Weight of water vapor in air
Prandtl Number
A dimensionless number approximating the ratio of momentum diffusivity to thermal diffusivity.
Removing Heat with Air
Calculating heat removed with air by measuring the wet bulb temperature.
Universal and Individual Gas Constants
