Densities
Density and specific volume of air varies with elevation above sea level.
Air - Density vs. Pressure and Temperatures
Thermal properties of air at different temperatures - density, viscosity, critical temperature and pressure, triple point, enthalpi and entropi, thermal conductivity and diffusivity and more.
API Gravity
API expresses the gravity or density of liquid petroleum products. Online API to Specific Gravity calculator.
Online calculator, figures and table showing density and specific weight of benzene, C6H6, at temperatures ranging from 5 to 325 °C (42 to 620 °F) at atmospheric and higher pressure - Imperial and SI Units.
Brick Densities
Densities of common types of bricks.
Calcium Chloride Water Solutions
Freezing point, density, specific heat and dynamic viscosity of Calcium Chloride Water coolants.
Carbon Dioxide - Thermophysical Properties
Carbon Monoxide - Density and Specific Weight vs. Temperature and Pressure
Online calculator, figures and tables showing density and specific weight of carbon monoxide, CO, at varying temperature and pressure - Imperial and SI Units.
Coal - Classification
Classification of coal based on volatile matter and cooking power of clean material.
Crude Oil Viscosity vs. Gravity
Viscosity at 20°C/68°F and 50°C/122°F for more than 120 crudes is shown as function of specific gravity@15°C/60°F.
Densities of common Products
Densities of common products - Imperial and SI-units.
Density Converter
An introduction to density, specific weight and specific gravity.
Dirt and Mud - Densities
Densities - pound per cubic foot and kilograms per cubic metre - of dirt and mud.
Ditch Filling Materials - Densities
Weight or density of ditch filling materials.
Dry Air - Thermodynamic and Physical Properties
Thermodynamic properties of dry air - specific heat, ratio of specific heats, dynamic viscosity, thermal conductivity, Prandtl number, density and kinematic viscosity at temperatures ranging 175 - 1900 K.
Energy Storage Density
Energy density - by weight and volume - for some ways to store energy
Ethanol - Thermophysical properties
Chemical, physical and thermal properties of ethanol (also called alcohol or ethyl alcohol). Phase diagram included.
Ethylene Glycol Heat-Transfer Fluid Properties
Food Products - Bulk Densities
Bulk densities of some common food products like grain, corn, barley, sugar and more.
Fuels - Densities and Specific Volumes
Densities and specific volumes fuels like anthracite, butane, gasoil, diesel, coke, oil, wood and more.
Gases - Densities
Hydrocarbons - Physical Data
Ice - Thermal Properties
Thermal and thermodynamic properties of ice like density, thermal conductivity and specific heat at temperatures from 0 to -100 oC.
Liquid-Liquid Solution - Shrinkage and Estimation of Density
It is possible to estimate the density of a liquid-liquid solution from the density of the solute and the solvent. However, due to shrinkage, the estimate will be a bit too low.
Liquids - Densities
Liquids - Specific Gravities
Specific gravities for common fluids like acetone, alcohol, turpentine, oil and more.
Specific gravities of liquids like alcohol, oils, benzene, water and many more.
Mercury - Thermodynamic Properties
Properties of saturated liquid Mercury - Hg - density, specific heat capacity, kinematic viscosity, thermal conductivity and Prandtl number.
Metals and Alloys - Densities
Online calculator, figures and tables showing density and specific weight of methanol,CH3OH, at varying temperature and pressure - Imperial and SI Units.
Minerals - Densities
Densities of minerals.
Moist Air - Density vs. Pressure
Density of moist air vs. pressure ranging 75 - 1000 mmHg.
Organic Nitrogen Compounds - Physical Data
Boiling and melting points of amines, diamines, pyrroles, pyridines, piperidines and quinolines shown together with their molecular structures, as well as molweights and density.
Viscosities and densities of SAE Grade oils.
Seawater - Properties
Seawater properties like density, saturation pressure, specific heat, electrical conductivity and absolute viscosity.
Slurry Densities
Calculate density of a slurry.
Solids - Densities
Densities of selected solids.
Toluene - Thermophysical Properties
Chemical, physical and thermal properties of toluene, also called methylbenzene, toluol and phenylmethane. Phase diagram included.
Definitions, online calculator and figures and tables with water properties like density, specific weight and thermal expansion coefficient of liquid water at temperatures ranging 0 to 360°C (32 to 680°F).
Water - Properties vs. Temperature and Pressure
Liquid water properties at temperatures between melting point and boiling point and pressures of 14.7 psia, 1000 psia and 10000 psia (1 atm, 68.1atm and 681 atm).
Wood - Density vs. Moisture Content
The density of wood versus moisture content.
Wood Species - Densities
  • The Engineering ToolBox (2017). Densities. [online] Available at: https://www.engineeringtoolbox.com/density-gravity-t_64.html [Accessed Day Month Year].
