Mechanics
Acceleration of gravity and Newton's Second Law - SI and Imperial units.
Acceleration Units Converter
Converting between units of acceleration.
American Standard Beams - S Beam
American Wide Flange Beams
Area Moment of Inertia - Typical Cross Sections I
Area Moment of Inertia - Typical Cross Sections II
Area Moment of Inertia, Moment of Inertia for an Area or Second Moment of Area for typical cross section profiles.
Area Moment of Inertia Converter
Convert between Area Moment of Inertia units.
Beams - Fixed at Both Ends - Continuous and Point Loads
Beams - Supported at Both Ends - Continuous and Point Loads
Belts - Power Transmission and Efficiency
Calculate belts power transmission and efficiency
Belts - Pulley Diameters vs. Speed
The pulley laws - driver and driven - diameter and rpm
Bodies Moving on Inclined Planes - Acting Forces
Required forces to move bodies up inclined planes.
Bollard Forces
Friction, load and effort forces acting in ropes turned around bollards.
Cable Loads
Force and tension in cables with uniform loads.
Car Acceleration
Car acceleration calculator.
Center Mass
Calculate position of center mass.
Center of Gravity
A body and the center of gravity.
Stability - the center of gravity vs. the center of buoyancy.
Centripetal and Centrifugal Acceleration Force
Forces due to circular motion and centripetal / centrifugal acceleration.
Conn-Rod Mechanism
The connecting rod mechanism.
Conservation of Momentum
The momentum of a body is the product of its mass and velocity - recoil calculator.
An introduction to density, specific weight and specific gravity.
Disk Brakes - Torque and Force
Forces and torque activated with disk brakes.
Drawbridge - Force and Moment vs. Elevation
Calculate the acting forces and moments when elevating drawbridges or beams.
Efficiency of Small Machine Elements
Friction and efficiency in bearings and roller chains.
Elevators - Force and Power
Required force and power to lift an elevator.
Energy
Energy is the capacity to do work.
Engineering Materials - Properties
Some typical properties of engineering materials like steel, plastics, ceramics and composites.
Equilibrant Force
The force required to keep a system of forces in equilibrium.
Fibre-reinforced Polymer Composites
Mechanical properties of fibers used to reinforce polymer composites.
Flywheels - Kinetic Energy
The kinetic energy stored in flywheels - the moment of inertia.
Force
Force Ratio
The force ratio is the load force versus the effort force.
Forces acting on Body Moving in a Horizontal Plane
The forces acting on bodies moved in horizontal planes.
Friction - Friction Coefficients and Calculator
Friction theory with calculator and friction coefficients for combinations of materials like ice, aluminum, steel, graphite and many more.
Gear Reducing Formulas
Output torque, speed and horsepower with gears.
Gear Trains - Bicycle Gearing Calculator
Gear train transmissions - bicycle gearing.
Gears
Gears effort force vs. load force.
Harmonic Oscillator
A simple harmonic oscillator.
HE-A Steel Beams
HE-B Steel Beams
HE-M Steel Beams
Properties of HE-M profile steel beams.
Hooke's Law
Hooke's law - force, elongation and spring constant.
Hot Air Balloons - Calculate Lifting Weights
Calculate hot air ballons lifting forces.
Improvised Torque Wrench
Impulse and Impulse Force
Forces acting a very short time are called impulse forces.
ISO 2841 - Spark Plugs Metric Threads
Metric threads spark plugs according ISO 28741.
Kinetic Energy
Energy possessed by an object's motion is kinetic energy.
Levers
Use levers to magnify forces.
Lifting Wheels
Loads and effort force with lifting wheels.
Mass Moment of Inertia
The Mass Moment of Inertia vs. mass of object, it's shape and relative point of rotation - the Radius of Gyration.
Mass vs. Weight
Metric Bolts - Minimum Ultimate Tensile and Proof Loads
Metric Nuts - Proof Loads
Proof loads of metric nuts - coarse and fine threads.
Modulus of Rigidity
Motors - Speed vs. Pulley Diameter
Pulley (Sheave) selection charts for motors ranging 850 - 3450 rpm.
Movement Ratio
Machines and movement ratio (velocity ratio).
Normal Flange I-Beams
Poisson's Ratio
When a material is stretched in one direction it tends to get thinner in the other two directions.
Poisson's Ratios Metals
Potential Energy - Hydropower
Power
Projectile Range
Calculate the range of a projectile - a motion in two dimensions.
Pulleys
Pulleys, blocks and tackles.
Radians vs. Degrees
Radius of Gyration in Structural Engineering
Radius of gyration describes the distribution of cross sectional area in columns around their centroidal axis.
Rolling Resistance
Rolling friction and rolling resistance.
Rotating Shafts - Torque
Torsional moments acting on rotating shafts.
Screw Jack - Effort Force vs. Load
Screw jacks and effort forces.
Section Modulus - Unit Converter
Convert between Elastic Section Modulus units.
Shafts Torsion
The torsion of solid or hollow shafts - Polar Moment of Inertia of Area.
Steel Bolts - ASTM Grades
Steel Bolts - SAE Grades
Stiffness
Stiffness is resistance to deflection.
Stress
Stress in Thick-Walled Cylinders or Tubes
Radial and tangential stress in thick-walled cylinders or tubes with closed ends - with internal and external pressure.
Stress in Thin-Walled Cylinders or Tubes
Hoop and longitudinal stress thin-walled tubes or cylinders.
Support Reactions - Equilibrium
Static equilibrium is achieved when the resultant force and resultant moment equals to zero.
Three-Hinged Arches - Continuous and Point Loads
Support reactions and bending moments.
Toggle Joint
A toggle joint mechanism can be used to multiply force.
Torque - Work done and Power Transmitted
The work done and power transmitted by a constant torque.
Trusses
Common types of trusses.
UNC and UNF - Unified Coarce and Unified Fine Inch Threads
Universal Gravitational Law
Gravitational attraction between two objects vs. mass of the objects and the distance between them.
Vector Addition
Online vector calculator - add vectors with different magnitude and direction - like forces, velocities and more.
W-Beams - American Wide Flange Beams
Weight of Beams - Stress and Strain
Stress and deformation of vertical beams due to own weight.
Wind Load vs. Wind Speed
Wind load on surface - Wind load calculator.
Wire Rope Slings
Work done by Force
Work done by a force acting on an object.
Young's Modulus, Tensile Strength and Yield Strength Values for some Materials
Young's Modulus (or Tensile Modulus alt. Modulus of Elasticity) and Ultimate Tensile Strength and Yield Strength for materials like steel, glass, wood and many more.
• Fasteners
• Threads
Thread data - metric, unified, ACME and others.
