Density is defined as mass per unit volume . Mass is a property and the SI unit for density is [kg/m3].
Density can be expressed as
ρ = m / V = 1 / ν (1)
ρ = density [kg/m3], [slugs/ft3]
m = mass [kg], [slugs]
V = volume [m3], [ft3]
ν = specific volume [m3 /kg], [ft3 /slug]
- What is weight and what is mass ? - the difference between weight and mass
The Imperial (U.S.) units for density are slugs /ft3 but pound-mass per cubic foot - lbm /ft3 - is often used. Note that there is a difference between pound-force (lbf) and pound-mass (lbm) . Slugs can be multiplied with 32.2 for a rough value in pound-mass (lbm) .
- 1 slug = 32.174 lbm = 14.594 kg
- 1 kg = 2.2046 lbm = 6.8521x10-2 slugs
- density of water: 1000 kg/m3, 1.938 slugs/ft3
See also Unit converter - mass and Unit converter - density
On atomic level - particles are packed tighter inside a substance with higher density. Density is a physical property - constant at a given temperature and pressure - and may be helpful for identification of substances.
Below on this page: Specific gravity (relative density) , Specific gravity for gases , Specific weight , Calculation examples
Se also:
- Densities for some common materials
- Water - Density, Specific Weight and Thermal Expantion Coefficient - variation with temperature at 1, 68 and 680 atm, SI and Imperial units
- Air - Density, Specific Weight and Thermal Expantion Coefficient - variation with temperature and pressure, SI and Imperial units
- How to measure density of liquid petroleum products
Specific Gravity (Relative Density) - SG - is a dimensionless unit defined as the ratio of the density of a substance to the density of water - at a specified temperature and can be expressed as
SG = ρsubstance / ρH2O (2)
SG = Specific Gravity of the substance
ρsubstance = density of the fluid or substance [kg/m3]
ρH2O = density of water - normally at temperature 4 oC [kg/m3]
It is common to use the density of water at 4 oC (39 oF) as a reference since water at this point has its highest density of 1000 kg/m 3 or 1.940 slugs/ft3 .
Since Specific Gravity - SG - is dimensionless, it has the same value in the SI system and the imperial English system (BG). SG of a fluid has the same numerical value as its density expressed in g/mL or Mg/m3 . Water is normally also used as reference when calculating the specific gravity for solids.
See also Thermophysical Properties of Water - Density, Freezing temperature, Boiling temperature, Latent heat of melting, Latent heat of evaporation, Critical temperature ...
Specific Gravity for some common Materials
Substance | Specific Gravity - SG - |
Acetylene | 0.0017 |
Air, dry | 0.0013 |
Alcohol | 0.82 |
Aluminum | 2.72 |
Brass | 8.48 |
Cadmium | 8.57 |
Chromium | 7.03 |
Copper | 8.79 |
Carbon dioxide | 0.00198 |
Carbon monoxide | 0.00126 |
Cast iron | 7.20 |
Hydrogen | 0.00009 |
Lead | 11.35 |
Mercury | 13.59 |
Nickel | 8.73 |
Nitrogen | 0.00125 |
Nylon | 1.12 |
Oxygen | 0.00143 |
Paraffin | 0.80 |
Petrol | 0.72 |
PVC | 1.36 |
Rubber | 0.96 |
Steel | 7.82 |
Tin | 7.28 |
Zinc | 7.12 |
Water (4 oC) | 1.00 |
Water, sea | 1.027 |
Wood, Oak | 0.77 |
Specific Gravity of gases is normally calculated with reference to air - and defined as the ratio of the density of the gas to the density of the air - at a specified temperature and pressure.
The Specific Gravity can be calculated asSG = ρgas / ρair (3)
SG = specific gravity of gas
ρgas = density of gas [kg/m3]
ρair = density of air (normally at NTP - 1.204 [kg/m3])
- NTP - Normal Temperature and Pressure - defined as 20 oC (293.15 K, 68 oF) and 1 atm (101.325 kN/m2, 101.325 kPa, 14.7 psia, 0 psig, 30 in Hg, 760 torr)
Molecular weights can be used to calculate Specific Gravity if the densities of the gas and the air are evaluated at the same pressure and temperature.
See also Thermophysical Properties of Air - density, viscosity, critical temperature and pressure, triple point, enthalpi and entropi, thermal conductivity and diffusicity,......
Specific Weight is defined as weight per unit volume . Weight is a force . The SI unit for specific weight is [N/m3]. The imperial unit is [lb/ft3].
Specific Weight (or force per unit volume) can be expressed as
γ = ρ a g (4)
γ = specific weight (N/m3], [lb/ft3]
a g = acceleration of gravity (9.807 [m/s2], 32.174 [ft/s2] under normal conditions)
Specific Weight for Some common Materials
Product | Specific Weight - γ - | |
Imperial Units (lb/ft3) | SI Units (kN/m3) | |
Aluminum | 172 | 27 |
Brass | 540 | 84.5 |
Carbon tetrachloride | 99.4 | 15.6 |
Copper | 570 | 89 |
Ethyl Alcohol | 49.3 | 7.74 |
Gasoline | 42.5 | 6.67 |
Glycerin | 78.6 | 12.4 |
Kerosene | 50 | 7.9 |
Mercury | 847 | 133.7 |
SAE 20 Motor Oil | 57 | 8.95 |
Seawater | 63.9 | 10.03 |
Stainless Steel | 499 - 512 | 78 - 80 |
Water | 62.4 | 9.81 |
Wrought Iron | 474 - 499 | 74 - 78 |
Example 1: Density of a Golf ball
A golf ball has a diameter of 42 mm and a mass of 45 g. The volume of the golf ball can be calculated as
V = (4/3) π (42 [mm] * 0.001 [m/mm]/2)3 = 3.8 10-5 [m3]
The density of the golf ball can then be calculated as
ρ = 45 [g] * 0.001 [kg/g] / 3.8 10-5 [m3] = 1184 [kg/m3]
Example 2: Using Density to Identify a Material
An unknown liquid substance has a mass of 18.5 g and occupies a volume of 23.4 ml (milliliter).
The density of the substance can be calculated as
ρ = (18.5 [g] /1000 [g/kg]) / (23.4 [ml] /(1000 [ml/l] * 1000[l/m3]))
= 18.5 10-3 [kg] /23.4 10-6 [m3] = 790 [kg/m3]
If we look up the densities of some common liquids we find that ethyl alcohol - or ethanol - has a density of 789 kg/m3 . The liquid may be ethyl alcohol!
Example 3: Density to Calculate Volume Mass
The density of titanium is 4507 kg/m3 . The mass of 0.17 m3 volume titanium can be calculated as
m = 0.17 [m3] * 4507 [kg/m3] = 766.2 [kg]
Note! - be aware that there is a difference between " bulk density" and actual "solid or material density". This may not be clear in the description of products. Always double check values with other sources before important calculations.
Example 4: Specific Gravity of Iron
The density of iron is 7850 kg/m3 . The specific gravity of iron related to water with density 1000 kg/m3 is
SG(iron) = 7850 [kg/m3] / 1000 [kg/m3] = 7.85
Example 5: Specific Weight of Water
The density of water is 1000 kg/m3 at 4 °C (39 °F).
The specific weight in SI units is
γ = 1000 [kg/m3] * 9.81 [m/s2] = 9810 [N/m3] = 9.81 [kN/m3]
The density of water is 1.940 slugs/ft3 at 39 °F (4 °C).
The specific weight in Imperial units is
γ = 1.940 [slugs/ft3] * 32.174 [ft/s2] = 62.4 [lb/ft3]
• Basics
• Beams and Columns
• Densities
• Mechanics
• Statics
Acceleration of gravity and Newton's Second Law - SI and Imperial units.
Acceleration Units Converter
Converting between units of acceleration.
Acetone - Density and Specific Weight
Online calculator, figures and tables showing density and specific weight of acetone at temperatures ranging from -95 to 275 °C (-138 to 530 °F) at atmospheric and higher pressure - Imperial and SI Units.
Air - Density vs. Pressure and Temperatures
Baume's Hydrometer
Liquid density with Degree Baume vs. Specific Gravity.
Online calculator, figures and table showing density and specific weight of benzene, C6H6, at temperatures ranging from 5 to 325 °C (42 to 620 °F) at atmospheric and higher pressure - Imperial and SI Units.
Cauchy Number
Introduction to the Cauchy Number.
Centrifugal Pumps - Viscosity Influence
Hydrodynamic losses through pumps depends on fluid viscosities.
Compression and Expansion of Gases
Isothermal and isentropic gas compression and expansion processes.
Crude Oil Viscosity vs. Gravity
Viscosity at 20°C/68°F and 50°C/122°F for more than 120 crudes is shown as function of specific gravity@15°C/60°F.
Densities of common Products
Densities of common products - Imperial and SI-units.
Density Converter
Dirt and Mud - Densities
Densities - pound per cubic foot and kilograms per cubic metre - of dirt and mud.
Ditch Filling Materials - Densities
Weight or density of ditch filling materials.
Engineering Materials - Properties
Some typical properties of engineering materials like steel, plastics, ceramics and composites.
Fuels - Densities and Specific Volumes
Densities and specific volumes fuels like anthracite, butane, gasoil, diesel, coke, oil, wood and more.
Gases - Specific Gravities
Specific gravities of air, ammonia, butadiene, carbon dioxide, carbon monoxide and some other common gases.
Gravity Heating System
The density difference between hot and cold water is the circulating force in a self circulating gravity heating system.
Hydrocarbon Mixtures - Average Boiling Points vs. Gravity and Molecular Weights
Formulas and examples of calculation of boiling point of hydrocarbon mixtures from gravity and molecular weight.
Hydrocarbon Mixtures - Molecular Weight vs. Gravity and Average Boiling Point
Formulas and examples of calculation of average molecular weight of hydrocarbon mixtures from gravity and average boiling point, achieved from distillation data.
Hydrocarbons - Physical Data
International Standard Atmosphere
International standard atmosphere in elevation -2000 to 30000 metre - pressure, temperature, density, viscosity, thermal conductivity and velocity of sound.
Levers
Use levers to magnify forces.
Liquids - Specific Gravities
Specific gravities of liquids like alcohol, oils, benzene, water and many more.
Specific gravities for common fluids like acetone, alcohol, turpentine, oil and more.
Mach Number
An introduction to the Mach Number.
Mass vs. Weight
Mercury - Thermodynamic Properties
Properties of saturated liquid Mercury - Hg - density, specific heat capacity, kinematic viscosity, thermal conductivity and Prandtl number.
Online calculator, figures and tables showing density and specific weight of methanol,CH3OH, at varying temperature and pressure - Imperial and SI Units.
Methanol Freeze Protected Heat Transfer Liquids
Freezing and flash points for methanol or methyl based heat-transfer fluids or brines.
Minerals and other Materials - Specific Gravities
Specific gravities for minerals and other materials.
Natural Gas - Pipe Sizing Calculator
Calculate capacities and dimensions of natural gas pipe lines.
Nitrogen - Density and Specific Weight vs. Temperature and Pressure
Online calculator, figures and tables showing density and specific weight of nitrogen, N2, at temperatures ranging from -175 to 1325 °C (-280 to 2400 °F) at atmospheric and higher pressure - Imperial and SI Units.
Nitrogen - Thermal Diffusivity vs. Temperature and Pressure
Figures and tables showing thermal diffusivity of nitrogen at varying temperarure and pressure, SI and Imperial units.
Ounces and Pounds vs. Grams
Converting ounces (ozs.) and pounds (lbs.) to grams (g).
Pitot Tubes
Pitot tubes can be used to measure fluid flow velocities by measuring the difference between static and dynamic pressure in the flow.
Porosity
Volume not occupied by solid material.
Solids - Densities
Densities of selected solids.
Solids and Metals - Specific Gravities
Specific gravity for common solids and metals like aluminum, asbestos, brass, calcium and many others.
Sugar Solubility in Water
Solubility of sugar in water.
The Ideal Gas Law
Troy Weight
Weight unit for preciuos metals like gold and silver.
U-Tube Differential Pressure Manometers
Inclined and vertical u-tube manometers used to measure differential pressure in flow meters like pitot tubes, orifices and nozzles.
Common converting units for Acceleration, Area, Density, Energy, Energy per unit mass, Force, Heat flow rate, Heat flux, Heat generation per unit volume and many more.
Universal Gravitational Law
Gravitational attraction between two objects vs. mass of the objects and the distance between them.
Wood Species - Densities
Yield Structure of Crude Oils with Increasing Density of Crude
Yields of different crude oil distillation cuts are plotted as function of whole crude specific gravity. Fractions based on European and North American markets, and the typical differences in crude oil fractionation in the two markets are also shown.
