Water - Dynamic (Absolute) and Kinematic Viscosity vs. Temperature and Pressure
Online Water Viscosity Calculator
The calculator below can be used to calculate the liquid water dynamic or kinematic viscosity at given temperatures.
The output dynamic viscosity is given as cP, mPa*s, Pa*s, N*s/m2,lbf *s/ft2and lbm /(ft*h),
Note! Temperature must be within the ranges 0-370 °C, 32-700 °F, 273-645 K and 492-1160 °R to get valid values.
See Water and Heavy Water - thermodynamic properties.
See also other properties of Water at varying temperature and pressure : Boiling points at high pressure , Boiling points at vacuum pressure , Density and specific weight , Enthalpy and entropy , Heat of vaporization , Ionization Constant, pK w , of normal and heavy water , Melting points at high pressure , Prandtl number , Properties at Gas-Liquid Equilibrium Conditions , Saturation pressure , Specific gravity , Specific heat (heat capacity) , Specific volume , Thermal conductivity , Thermal diffusivity and Vapour pressure at gas-liquid equilibrium .
See also dynamic and kinematic viscosity of air , ammonia , benzene , butane , carbon dioxide , ethane , ethanol , ethylene , methane , methanol , nitrogen , oxygen and propane
The figures and tables below shows how water viscosity changes with temperature (°C and °F) at water saturation pressure (which for practicle use, gives the same result as atmospheric pressure at temperatures < 100 °C (212°F)). One figure showing relative viscosity with variations in pressure and temperature is also included.
water_viscosity
water_viscosity
water_temp_pressure_viscosity
Temperature Pressure Dynamic viscosity Kinematic viscosity
[°C] [MPa] [Pa s], [N s/m2] [cP], [mPa s] [lbf s/ft2*10 -5 ] [m2/s*10-6 ], [cSt])
0.01 0.000612 0.0017914 1.79140 3.7414 1.7918
10 0.0012 0.0013060 1.30600 2.7276 1.3065
20 0.0023 0.0010016 1.00160 2.0919 1.0035
25 0.0032 0.0008900 0.89004 1.8589 0.8927
30 0.0042 0.0007972 0.79722 1.6650 0.8007
40 0.0074 0.0006527 0.65272 1.3632 0.6579
50 0.0124 0.0005465 0.54650 1.1414 0.5531
60 0.0199 0.0004660 0.46602 0.9733 0.4740
70 0.0312 0.0004035 0.40353 0.8428 0.4127
80 0.0474 0.0003540 0.35404 0.7394 0.3643
90 0.0702 0.0003142 0.31417 0.6562 0.3255
100 0.101 0.0002816 0.28158 0.5881 0.2938
110 0.143 0.0002546 0.25461 0.5318 0.2677
120 0.199 0.0002320 0.23203 0.4846 0.2460
140 0.362 0.0001966 0.19664 0.4107 0.2123
160 0.618 0.0001704 0.17043 0.3559 0.1878
180 1.00 0.0001504 0.15038 0.3141 0.1695
200 1.55 0.0001346 0.13458 0.2811 0.1556
220 2.32 0.0001218 0.12177 0.2543 0.1449
240 3.35 0.0001111 0.11106 0.2320 0.1365
260 4.69 0.0001018 0.10181 0.2126 0.1299
280 6.42 0.0000936 0.09355 0.1954 0.1247
300 8.59 0.0000859 0.08586 0.1793 0.1206
320 11.3 0.0000783 0.07831 0.1636 0.1174
340 14.6 0.0000703 0.07033 0.1469 0.1152
360 18.7 0.0000603 0.06031 0.1260 0.1143
[°F] [psi] [lbf s/ft2*10 -5 ] [lbm /(ft h)] [cP], [mPa s] [ft2/s*10 -5 ]
32.02 0.9506 3.7414 4.3336 1.7914 1.9287
34 0.0962 3.6047 4.1752 1.7259 1.8579
39.2 0.1180 3.2801 3.7992 1.5705 1.6906
40 0.1217 3.2340 3.7458 1.5484 1.6668
50 0.1781 2.7276 3.1593 1.3060 1.4063
60 0.2563 2.3405 2.7109 1.1206 1.2075
70 0.3634 2.0337 2.3556 0.9737 1.0503
80 0.5076 1.7888 2.0719 0.8565 0.9250
90 0.6992 1.5896 1.8411 0.7611 0.8234
100 0.9506 1.4243 1.6497 0.6820 0.7392
110 1.277 1.2847 1.4880 0.6151 0.6682
120 1.695 1.1652 1.3496 0.5579 0.6075
130 2.226 1.0620 1.2300 0.5085 0.5551
140 2.893 0.9733 1.1273 0.4660 0.5102
150 3.723 0.8950 1.0366 0.4285 0.4706
160 4.747 0.8279 0.9589 0.3964 0.4367
170 6.000 0.7698 0.8916 0.3686 0.4074
180 7.520 0.7192 0.8330 0.3444 0.3820
190 9.349 0.6745 0.7813 0.3230 0.3596
200 11.537 0.6300 0.7297 0.3016 0.3371
212 14.710 0.5881 0.6812 0.2816 0.3163
220 17.203 0.5619 0.6508 0.2690 0.3032
240 25.001 0.5050 0.5850 0.2418 0.2750
260 35.263 0.4575 0.5299 0.2191 0.2515
280 49.286 0.4176 0.4837 0.2000 0.2320
300 67.264 0.3840 0.4448 0.1839 0.2157
350 134.73 0.3202 0.3708 0.1533 0.1853
400 247.01 0.2750 0.3185 0.1317 0.1648
450 422.32 0.2404 0.2785 0.1151 0.1504
500 680.56 0.2126 0.2463 0.1018 0.1398
550 1045.0 0.1888 0.2187 0.0904 0.1322
600 1542.1 0.1673 0.1937 0.0801 0.1270
625 1851.2 0.1562 0.1809 0.0748 0.1252
650 2207.8 0.1438 0.1666 0.0689 0.1239
675 2618.7 0.1292 0.1496 0.0619 0.1230
Unit conversion
Viscosity Dynamic, Absolute
centipoise [cP], gram/(centimetre second) [g/(cm s)] = poise [P],  kilogram/metre second [kg/m s]=newton second/square metre [N s/m2]= pascal second [Pa s], pound/(foot hour) [lb/(ft h)], pound/(foot second) [lb/(ft s)], reyn [reyn]
  • 1 reyn = 6894.76 Pa s
See also Absolute or Dynamic Viscosity Unit Converter
Viscosity Kinematic
centistoke [cSt] = square millimetre/second [mm2/s], square foot/hour [ft2/h], square foot/second [ft2/s], square inch/second [in2/s], square metre/hour [m2/h], square metre/second [m2/s], stoke [St] = square centimetre/second [cm2/s]
See also Kinematic Viscosity Unit Converter
  • Steam and Condensate
  • Viscosities
  • Water Systems
  • The Engineering ToolBox (2004). Water - Dynamic (Absolute) and Kinematic Viscosity vs. Temperature and Pressure. [online] Available at: https://www.engineeringtoolbox.com/water-dynamic-kinematic-viscosity-d_596.html [Accessed Day Month Year].
