See also
- Elements of the Periodic System for weights, melting and boiling points, density, electronegativity and electron affinity, and electron configuration for all elements.
- Boiling and melting points of different kinds of organic compounds
Substance (at 1 atm) | Melting Point1) - Tm - (K) | Heat of Fusion2) - Lf - (kcal/kg) | Boiling Point3) - Tb - (K) | Heat of Evaporation4) - Lv - (kcal/kg) |
Aluminum | 932 | 94.5 | 2740 | 2500 |
Bismuth | 544 | 12.5 | 1193 | 190 |
Bromine | 266 | 16 | 333 | 43 |
Copper | 1359 | 32.0 | 1460 | 1210 |
Ethyl Alcohol | 159 | 24.9 | 351 | 205 |
Gold | 1336 | 15.4 | 2933 | 377 |
Hydrogen | 13.8 | 14.0 | 20.3 | 108 |
Iron | 1808 | 69.1 | 3023 | 1520 |
Lead | 600 | 5.9 | 2023 | 208 |
Lithium | 459 | 160 | 1609 | 511 |
Mercury | 234 | 2.7 | 630 | 70.0 |
Nitrogen | 63.3 | 6.1 | 77.3 | 48.0 |
Oxygen | 54.4 | 3.3 | 90.2 | 50.9 |
Sulfuric acid | 282 | 39 | 599 | 122 |
Water | 273.15 | 79.7 | 373.15 | 539 |
Zinc | 693 | 24 | 1191 | 475 |
1) The melting point of a solid is the temperature at which it changes state from solid to fluid.
2) Heat of fusion is the thermal energy which must be withdrawn to solidify a certain mass or quantity of fluid or added to melt a certain mass or quantity of solid. It is also called the latent heat of fusion or the enthalpy of fusion, and the temperature at which it occurs is called the melting point.
3) The boiling point of a substance is the temperature at which it can change state from a liquid to a gas throughout the bulk of the liquid.
4) Heat of evaporation describes the amount of energy in the form of heat that is required for a material to undergo a change of phase from fluid to gas.
- 1 kcal/kg = 1 cal/g = 4.1868 kJ/kg = 1.8 Btu/lbm
Boiling Points of Fluids
Boiling points of elements, products and chemical species at varying conditions. -
Material Properties
Melting and Freezing Points
Copper Binary Eutectic Alloys - Melting Points
Cu - Copper - binary eutectic alloys and their melting points. -
The elements of the periodic system with names, symbols, atomic numbers and weights, melting and boiling points, density, electronegativity and electron affinity, and electron configuration. -
Boiling temperatures (°C and °F) with varying carbon numbers up to C33. -
Latent heat of fusion when changing between solid or liquid state for common materials like aluminum, ammonia, glycerin, water and more. -
Boiling temperatures for common liquids and gases - acetone, butane, propane and more. -
Melting and Boiling Temperatures - Evaporation and Melting Heats common Materials
Melting and boiling point temperatures, latent heat of evaporation, and melting heat of common substances like copper, gold, lead and more - SI units. -
Metal Alloys - Melting Points
Alloys and their melting points. -
Metals - Boiling Points and Specific Heat
Boiling points and specific heat of liquid metals. -
