Cast Iron Soil Pipes - Dimensions
Dimensions of cast iron soil pipes.
Dimensions of cast iron soil pipe and fittings:
Service Cast Iron
Size (in) | Inside Diameter of Hub (in) | Outside Diameter of Barrel (in) | Inside Diameter barrel (in) |
2 | 2.94 | 2.30 | 1.96 |
3 | 3.94 | 3.30 | 2.96 |
4 | 4.94 | 4.30 | 3.94 |
5 | 5.94 | 5.30 | 4.94 |
6 | 6.94 | 6.30 | 5.94 |
8 | 9.25 | 8.38 | 7.94 |
10 | 11.38 | 10.50 | 9.94 |
12 | 13.50 | 12.50 | 11.94 |
Extra Heavy Cast Iron
2 | 3.06 | 2.38 | 2.00 |
3 | 4.19 | 3.50 | 3.00 |
4 | 5.19 | 4.50 | 4.00 |
5 | 6.19 | 5.50 | 5.00 |
6 | 7.19 | 6.50 | 6.00 |
8 | 9.50 | 8.62 | 8.00 |
10 | 11.62 | 10.75 | 10.00 |
12 | 13.75 | 12.75 | 12.00 |
Sanitary Drainage Systems
The purpose of the sanitary drainage system is to remove effluent discharged from plumbing fixtures and other equipment.
Standard dimensions and weight of PVC - Polyvinyl Chloride - and CPVC - Chlorinated Polyvinyl Chloride. -
ASTM D2729 - Poly(Vinyl Chloride) (PVC) Sewer Pipe - Dimensions
Dimensions of Poly(Vinyl Chloride) (PVC) Sewer Pipes with belled end. -
Cast Iron
The four basic types of cast iron - white iron, gray iron, ductile iron and malleable iron. -
Cast Iron Flanges - ASME/ANSI Class 125
ASME/ANSI B16.1 Cast Iron Pipe Flanges and Flanged Fittings - Class 125 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts. -
Cast Iron Flanges - ASME/ANSI Class 250
ASME/ANSI B16.1 Cast Iron Pipe Flanges and Flanged Fittings - Class 250 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts. -
Cleanouts in Draining Systems
Cleanouts provides access to the sewer for rodding. -
DFU - Drainage Fixture Units
DFU are used to calculate the drainage flow from fixtures and the required capacities of sewer service systems. -
Drain Waste and Vent Pipes - Hanger Spacing
Support of Drain Waste and Vent - DWV - pipes. -
Draining Systems - Main Vents
Vents in draining systems protects traps against pressure differences that could cause them to siphon or blow out . -
Drains and Sewers - Capacities vs. Size
Drainage Fixture Units (DFU) connected to building drains and sewers. -
Fixtures Trap Sizes
Recommended drain trap sizes for different types of fixtures -
Horizontal Storm Drain Piping
Capacities of horizontal storm drain piping systems. -
Iron - Density, Specific Heats and Thermal Conductivities vs. Temperatures
Specific heat, density and thermal conductivity of iron related to temperature. -
Sanitary Drainage Systems - Volume Flow
Calculate expected volume flow load in sanitary drainage systems. -
Maximum Drainage Fixture Unit - DFU - loads in sanitary piping systems. -
Sewage Sludge - Viscosities
Viscosity of sewage sludge vs. content of solids. -
Carrying capacities of sewer and wastewater pipes - gpm and liter per second. -
Waste Water Piping - Flow Capacities vs. Dimensions
In sewage piping and pumping systems the fluid flow rate must be kept within certain limits to avoid operating problems.
