Water - Dynamic (Absolute) and Kinematic Viscosity vs. Temperature and Pressure
The viscosity of a fluid is a measure of its resistance to gradual deformation by shear stress or tensile stress .
Online Water Viscosity Calculator
The calculator below can be used to calculate the liquid water dynamic or kinematic viscosity at given temperatures.
The output dynamic viscosity is given as cP, mPa*s, Pa*s, N*s/m2,lbf *s/ft2and lbm /(ft*h),
Note! Temperature must be within the ranges 0-370 °C, 32-700 °F, 273-645 K and 492-1160 °R to get valid values.
See Water and Heavy Water - thermodynamic properties.
See also other properties of Water at varying temperature and pressure : Boiling points at high pressure , Boiling points at vacuum pressure , Density and specific weight , Enthalpy and entropy , Heat of vaporization , Ionization Constant, pK w , of normal and heavy water , Melting points at high pressure , Prandtl number , Properties at Gas-Liquid Equilibrium Conditions , Saturation pressure , Specific gravity , Specific heat (heat capacity) , Specific volume , Thermal conductivity , Thermal diffusivity and Vapour pressure at gas-liquid equilibrium .
See also dynamic and kinematic viscosity of air , ammonia , benzene , butane , carbon dioxide , ethane , ethanol , ethylene , methane , methanol , nitrogen , oxygen and propane
The figures and tables below shows how water viscosity changes with temperature (°C and °F) at water saturation pressure (which for practicle use, gives the same result as atmospheric pressure at temperatures < 100 °C (212°F)). One figure showing relative viscosity with variations in pressure and temperature is also included.
Temperature | Pressure | Dynamic viscosity | Kinematic viscosity | ||
[°C] | [MPa] | [Pa s], [N s/m2] | [cP], [mPa s] | [lbf s/ft2*10 -5 ] | [m2/s*10-6 ], [cSt]) |
0.01 | 0.000612 | 0.0017914 | 1.79140 | 3.7414 | 1.7918 |
10 | 0.0012 | 0.0013060 | 1.30600 | 2.7276 | 1.3065 |
20 | 0.0023 | 0.0010016 | 1.00160 | 2.0919 | 1.0035 |
25 | 0.0032 | 0.0008900 | 0.89004 | 1.8589 | 0.8927 |
30 | 0.0042 | 0.0007972 | 0.79722 | 1.6650 | 0.8007 |
40 | 0.0074 | 0.0006527 | 0.65272 | 1.3632 | 0.6579 |
50 | 0.0124 | 0.0005465 | 0.54650 | 1.1414 | 0.5531 |
60 | 0.0199 | 0.0004660 | 0.46602 | 0.9733 | 0.4740 |
70 | 0.0312 | 0.0004035 | 0.40353 | 0.8428 | 0.4127 |
80 | 0.0474 | 0.0003540 | 0.35404 | 0.7394 | 0.3643 |
90 | 0.0702 | 0.0003142 | 0.31417 | 0.6562 | 0.3255 |
100 | 0.101 | 0.0002816 | 0.28158 | 0.5881 | 0.2938 |
110 | 0.143 | 0.0002546 | 0.25461 | 0.5318 | 0.2677 |
120 | 0.199 | 0.0002320 | 0.23203 | 0.4846 | 0.2460 |
140 | 0.362 | 0.0001966 | 0.19664 | 0.4107 | 0.2123 |
160 | 0.618 | 0.0001704 | 0.17043 | 0.3559 | 0.1878 |
180 | 1.00 | 0.0001504 | 0.15038 | 0.3141 | 0.1695 |
200 | 1.55 | 0.0001346 | 0.13458 | 0.2811 | 0.1556 |
220 | 2.32 | 0.0001218 | 0.12177 | 0.2543 | 0.1449 |
240 | 3.35 | 0.0001111 | 0.11106 | 0.2320 | 0.1365 |
260 | 4.69 | 0.0001018 | 0.10181 | 0.2126 | 0.1299 |
280 | 6.42 | 0.0000936 | 0.09355 | 0.1954 | 0.1247 |
300 | 8.59 | 0.0000859 | 0.08586 | 0.1793 | 0.1206 |
320 | 11.3 | 0.0000783 | 0.07831 | 0.1636 | 0.1174 |
340 | 14.6 | 0.0000703 | 0.07033 | 0.1469 | 0.1152 |
360 | 18.7 | 0.0000603 | 0.06031 | 0.1260 | 0.1143 |
[°F] | [psi] | [lbf s/ft2*10 -5 ] | [lbm /(ft h)] | [cP], [mPa s] | [ft2/s*10 -5 ] |
32.02 | 0.9506 | 3.7414 | 4.3336 | 1.7914 | 1.9287 |
34 | 0.0962 | 3.6047 | 4.1752 | 1.7259 | 1.8579 |
39.2 | 0.1180 | 3.2801 | 3.7992 | 1.5705 | 1.6906 |
40 | 0.1217 | 3.2340 | 3.7458 | 1.5484 | 1.6668 |
50 | 0.1781 | 2.7276 | 3.1593 | 1.3060 | 1.4063 |
60 | 0.2563 | 2.3405 | 2.7109 | 1.1206 | 1.2075 |
70 | 0.3634 | 2.0337 | 2.3556 | 0.9737 | 1.0503 |
80 | 0.5076 | 1.7888 | 2.0719 | 0.8565 | 0.9250 |
90 | 0.6992 | 1.5896 | 1.8411 | 0.7611 | 0.8234 |
100 | 0.9506 | 1.4243 | 1.6497 | 0.6820 | 0.7392 |
110 | 1.277 | 1.2847 | 1.4880 | 0.6151 | 0.6682 |
120 | 1.695 | 1.1652 | 1.3496 | 0.5579 | 0.6075 |
130 | 2.226 | 1.0620 | 1.2300 | 0.5085 | 0.5551 |
140 | 2.893 | 0.9733 | 1.1273 | 0.4660 | 0.5102 |
150 | 3.723 | 0.8950 | 1.0366 | 0.4285 | 0.4706 |
160 | 4.747 | 0.8279 | 0.9589 | 0.3964 | 0.4367 |
170 | 6.000 | 0.7698 | 0.8916 | 0.3686 | 0.4074 |
180 | 7.520 | 0.7192 | 0.8330 | 0.3444 | 0.3820 |
190 | 9.349 | 0.6745 | 0.7813 | 0.3230 | 0.3596 |
200 | 11.537 | 0.6300 | 0.7297 | 0.3016 | 0.3371 |
212 | 14.710 | 0.5881 | 0.6812 | 0.2816 | 0.3163 |
220 | 17.203 | 0.5619 | 0.6508 | 0.2690 | 0.3032 |
240 | 25.001 | 0.5050 | 0.5850 | 0.2418 | 0.2750 |
260 | 35.263 | 0.4575 | 0.5299 | 0.2191 | 0.2515 |
280 | 49.286 | 0.4176 | 0.4837 | 0.2000 | 0.2320 |
300 | 67.264 | 0.3840 | 0.4448 | 0.1839 | 0.2157 |
350 | 134.73 | 0.3202 | 0.3708 | 0.1533 | 0.1853 |
400 | 247.01 | 0.2750 | 0.3185 | 0.1317 | 0.1648 |
450 | 422.32 | 0.2404 | 0.2785 | 0.1151 | 0.1504 |
500 | 680.56 | 0.2126 | 0.2463 | 0.1018 | 0.1398 |
550 | 1045.0 | 0.1888 | 0.2187 | 0.0904 | 0.1322 |
600 | 1542.1 | 0.1673 | 0.1937 | 0.0801 | 0.1270 |
625 | 1851.2 | 0.1562 | 0.1809 | 0.0748 | 0.1252 |
650 | 2207.8 | 0.1438 | 0.1666 | 0.0689 | 0.1239 |
675 | 2618.7 | 0.1292 | 0.1496 | 0.0619 | 0.1230 |
Unit conversion
Viscosity Dynamic, Absolute
centipoise [cP], gram/(centimetre second) [g/(cm s)] = poise [P], kilogram/metre second [kg/m s]=newton second/square metre [N s/m2]= pascal second [Pa s], pound/(foot hour) [lb/(ft h)], pound/(foot second) [lb/(ft s)], reyn [reyn]
- 1 cP = 0.001 Pa s = 0.01 P = = 0.01 g/(cm sec) = 6.72197x10-4 lb/(ft s) = 2.4191 lb/(ft h)
- 1 lb/(ft h) = 0.00027778 lb/(ft s) = 0.00041338 Pa s = 0.0041338 P = 0.41338 cP
- 1 lb/(ft s) = 3600 lb/(ft h) = 1.48816 Pa s = 14.8816 P = 1488.16 cP
- 1 kg/(m s ) = 1 (N s)/m2= 1 Pa s = 10 P = 1000 cP = 0.672197 lb/(ft s) = 2419.09 lb/(ft h)
- 1 (N s)/m2= 1 kg/(m s ) = 1 Pa s = 10 P = 1000 cP = 0.672197 lb/(ft s) = 2419.09 lb/(ft h)
- 1 P = 1 g/(cm s) = 0.1 Pa s = 100 cP = 0.067197 lb/(ft s) = 241.909 lb/(ft h)
- 1 Pa s = 1 kg/(m s) = 1 (N s)/m2= 10 P = 1000 cP = 0.672197 lb/(ft s) = 2419.08 lb/(ft h) = 0.00014504 reyn
- 1 reyn = 6894.76 Pa s
See also Absolute or Dynamic Viscosity Unit Converter
Viscosity Kinematic
centistoke [cSt] = square millimetre/second [mm2/s], square foot/hour [ft2/h], square foot/second [ft2/s], square inch/second [in2/s], square metre/hour [m2/h], square metre/second [m2/s], stoke [St] = square centimetre/second [cm2/s]
- 1 cm2/s = 1 St = 100 mm2/s = 100 cSt = 1x10-4 m2/s = 0.36 m2/h = 1.07639x10-3 ft2/s = 3.875008 ft2/h = 0.1550003 in2/s
- 1 cSt = 1 mm2/s = 0.01 St = 1x10-6 m2/s = 0.0036 m2/h = 1.07639x10 -5 ft2/s = 0.03875008 ft2/h = 0.001550003 in2/s
- 1 ft2/h = 2.7778x10-4 ft2/s = 0.04 in2/s = 2.58064x10 -5 m2/s = 0.09290304 m2/h = 25.8064 cS = 0.258064 St
- 1 ft2/s = 3600 ft2/h = 144 in2/s = 0.09290304 m2/s = 334.451 m2/h = 92903.04 cSt = 929.0304 St
- 1 in2/s = 0.0069444 ft2/s = 25 ft2/h = 0.00064516 m2/s = 2.322576 m2/h = 645.16 cSt = 6.4516 St
- 1 m2/h = 1/3600 m2/s = 2.7778x10-4 m2/s = 2.7778 cm2/s = 277.78 mm2/s = 277.78 cSt = 2.7778 St = 0.00298998 ft2/s = 10.7639 ft2/h = 0.430556 in2/s
- 1 m2/s = 3600 m2/h = 1x104 cm2/s = 1x104 St = 1x106 mm2/s = 1x106 cSt = 10.7639 ft2/s = 38750.08 ft2/h = 1550003 in2/s
- 1 mm2/s = 1 cSt = 1x10-6 m2/s = 0.0036 m2/h = 0.01 cm2/s = 0.01 St = 1.07639x10 -5 ft2/s = 0.03875008 ft2/h = 0.001550003 in2/s
- 1 St = 1 cm2/s = 100 cSt = 100 mm2/s = 1x10-4 m2/s = 0.36 m2/h = 1.076x10-3 ft2/s = 3.875008 ft2/h = 0.1550003 in2/s
See also Kinematic Viscosity Unit Converter
• Steam and Condensate
• Viscosities
• Water Systems
Dynamic (Absolute) Viscosity - Converting Chart
Convert dynamic viscosity values between units like Poiseuille - Poise - centiPoise and more.
Kinematic Viscosity - Convert between Units
Convert between Centistokes, Saybolt and Redwood seconds.
Sewage Sludge - Viscosities
Viscosity of sewage sludge vs. content of solids.
Steel Pipes - Friction Loss vs. Viscous Liquid Flow
Friction loss in schedule 40 steel pipe with viscous liquids - viscosities ranging from water to oil.
Sugar Water Solutions - Viscosities
Dynamic viscosities of sucrose water solutions vs. temperature.
Water - Absolute (Dynamic) Viscosity vs. Temperature and Pressure
Absolute viscosity for water in centipoises for temperatures between 32 - 200oF.
Definitions, online calculator and figures and tables with water properties like density, specific weight and thermal expansion coefficient of liquid water at temperatures ranging 0 to 360°C (32 to 680°F).
Water - Heat of Vaporization vs. Temperature
Ionization constant (= dissociation constant = self-ionization constant = ion product = autoprotolysis constant ) of water and heavy water, given as function of temperature (°C and °F) in figures and tables.
Water - Saturation Pressure vs. Temperature
Water - Specific Heat vs. Temperature
