AWG - American Wire Gauge Converting Chart
AWG - American Wire Gauge - is an U.S. standard for wire conductor size. The "gauge" is related to the diameter of the wire.
- larger "gauge" -> smaller diameter and thinner wire
The AWG standard includes copper, aluminum and other wire materials. Typical household copper wiring is AWG number 12 or 14. Telephone wire is usually 22, 24, or 26. The higher the gauge number, the smaller the diameter and the thinner the wire.
The table below can be used to convert American Wire Gauge (AWG) to square mm cross sectional area.
American Wire Gauge (#AWG) | Diameter (inches) | Diameter (mm) | Cross Sectional Area (mm2) |
0000 (4/0) | 0.460 | 11.7 | 107 |
000 (3/0) | 0.410 | 10.4 | 85.0 |
00 (2/0) | 0.365 | 9.27 | 67.4 |
0 (1/0) | 0.325 | 8.25 | 53.5 |
1 | 0.289 | 7.35 | 42.4 |
2 | 0.258 | 6.54 | 33.6 |
3 | 0.229 | 5.83 | 26.7 |
4 | 0.204 | 5.19 | 21.1 |
5 | 0.182 | 4.62 | 16.8 |
6 | 0.162 | 4.11 | 13.3 |
7 | 0.144 | 3.67 | 10.6 |
8 | 0.129 | 3.26 | 8.36 |
9 | 0.114 | 2.91 | 6.63 |
10 | 0.102 | 2.59 | 5.26 |
11 | 0.0907 | 2.30 | 4.17 |
12 | 0.0808 | 2.05 | 3.31 |
13 | 0.0720 | 1.83 | 2.63 |
14 | 0.0641 | 1.63 | 2.08 |
15 | 0.0571 | 1.45 | 1.65 |
16 | 0.0508 | 1.29 | 1.31 |
17 | 0.0453 | 1.15 | 1.04 |
18 | 0.0403 | 1.02 | 0.82 |
19 | 0.0359 | 0.91 | 0.65 |
20 | 0.0320 | 0.81 | 0.52 |
21 | 0.0285 | 0.72 | 0.41 |
22 | 0.0254 | 0.65 | 0.33 |
23 | 0.0226 | 0.57 | 0.26 |
24 | 0.0201 | 0.51 | 0.20 |
25 | 0.0179 | 0.45 | 0.16 |
26 | 0.0159 | 0.40 | 0.13 |
Note! - the diameter of a solid and stranded wire with the same AWG is not identical. The diameter of a stranded wire is larger than the diameter of a solid wire.
• Electrical
12 Volt - Electric Automotive Wiring
Maximum wire lengths vs. currents in the 12 volt electrical system of a car.
12 Volt - Maximum Wire Length vs. Current
Maximum length of copper wire with 2% voltage drop.
12 Volt - Wire Gauge vs. Amps
Maximum current (amps) in a 12V electrical circuit vs. size (AWG) and length of wire.
AWG - American Wire Gauge Current Ratings
Amp ratings vs. US AWG wire gauges.
AWG - American Wire Gauge vs. Circular Mils
AWG vs. diameter mil, circular mil, diameter in mm and area in mm2.
Copper and Aluminum Wire - Max Amps vs. Gauge
Maximum current in copper and aluminum wire.
Copper Wire - Electrical Resistance vs. Gauge
Gauge, weight, circular mils and electrical resistance in copper wire.
Electric Cable Size vs. Current Rating
Amps vs. cable size for fixed installations in buildings.
Electric Wire - Maximum Length with 240 Volts Single-Phase Power
Maximum length of 240 V single phase electric wire with max. 2% voltage drop.
Electric Wire - Resistance
Electric resistance in wire made of Copper, Aluminum, Brass, Constantan, Nichrome, Platinum, Silver or Tungsten.
Electrical Conductivity - Elements and other Materials
Electric conductance is the ability of a element to conduct an electric current.
Electrical Metal Tubing (EMT) - Conduits
Trade sizes and max. distance between conduit supports.
Electrical Motors - Single Phase 230 V Circuit Wiring
Copper wire gage and transformer size for single phase 230 volts electrical motors.
Intermediate Metal Conduit - IMC
Lighter and lower cost metal conduits.
Nickel-Chromium Heater Wire - Temperature Rise vs. Amps
Electric resistance vs. temperature rise for Nickel-Chromium electrical heater wire.
Rigid Aluminum Conduit - RAC
Rigid Aluminum Conduit dimensions.
Standard Gauges
Standard gauges for wire and sheet - American, Birmingham, Washburn, Music, Stubs ..
SWG - Standard Wire Gauge
Imperial Standard Wire Gauge used with wire and sheet metal.
Weight vs. Gauges Chart
Gauge and weight chart for sheet steel, galvanized steel, stainless steel, aluminum and strip & tubing.
