This application can be used to design Water Supply Systems.
How to Use
  • Make a sketch of your system - something similar to the default sketch below. Custom drawings can be linked to the application - any global (http://..) or local (file://..) url should work
  • Tag the sections and add them to the hierarchical application structure below (modify or reset the default system)
  • Add input data - flow, preliminary dimensions, lengths, elevations, minor coefficients and so on for each section
  • Modify the dimensions to achieve reasonable values for velocities and pressure losses
  • Save the data file to your computer/network
  • dimensions, copper, pvc, pe
  • minor loss coefficients, viscosity, density, roughness
  • Water Systems
  • The Engineering ToolBox (2019). Water Supply Systems - Online Design Application. [online] Available at: https://www.engineeringtoolbox.com/water-supply-system-design-d_2157.html [Accessed Day Month Year].
