Stainless Steel Pipes - American vs. European Standards
American - US - vs. European - German, British (UK) and Swedish - stainless steel pipe standards.
The table below can be used to compare American and European stainless steel standards.
USAUKGermanySweden
AISI BSI Werkstoff Nr. DIN 17006 SIS
304
304S15
304S16
1.4301
1.4303
X 5 CrNi 18 10
X 5 CrNi 18 12
23 32
304L 304S11 1.4306 X 2 CrNi 18 11 23 52
310 310S24 1.4845 X 12 CrNi 25 21
316 316S31 1.4401 X 5 CrNiMo 17 12 2 23 47
316L 316S11 1.4404 X 2 CrNiMo 17 13 2 23 48
317L 317S12 1.4438 X 2 CrNiMo 18 16 4 23 67
321 321S31
1.4541
1.4878
X 6 CrNiTi 18 10
X 12 CrNiTi 18 9
23 37
347 347S31 1.4550 X 6 CrNiNb 18 10 23 38
  • A312/A312M-02 Standard Specification for Seamless and Welded Austenitic Stainless Steel Pipes covers seamless, straight-seam welded, and heavily cold worked welded austenitic stainless steel pipe intended for high-temperature and general corrosive service.
  • BS 3605-[1-2]:1991  Austenitic stainless steel pipes and tubes for pressure purposes
  • Piping Codes and Standards
  • Piping Systems
  • The Engineering ToolBox (2003). Stainless Steel Pipes - American vs. European Standards. [online] Available at: https://www.engineeringtoolbox.com/stainless-steel-pipes-standards-d_32.html [Accessed Day Month Year].
